ya@yousifastarabadi· 719 views
J5 linear rods sliding
Both linear rods in the J5 assembly are sliding out and in when the J5 motor is activated. I have used the set screws and loctite, but the motor seems like its too powerful and breaks the bond. Has anyone had this problem or a solution to it?
Make sure that the linear rod is pushed in far enough so that the set screw actually bites onto it.
