Alastair Green@alastairgreen· 319 views
Manual / kit fastener question
Hi, I bought the full kit and have just finished getting J1 set up and have encountered a few issues I'd like to get some clarification on before I move on.
This one not a big deal but on page 55 just curious why we solder an extension to the red switch wire? I did this, then later when connecting it up to the driver it is too long so ended up just cutting it off again. What am I missing here?
Page 59 calls for #4 plastic thread form screws but my kit only has #6 thread form screws so I used them. Unfortunately looking ahead the build appears to require a total of 28 of these but the kit only supplies 26. Am I using the wrong fastener here then?
Thanks, Al
Comment 2
Hello, I've had some supply chain issues and depending on supplier I've had some batches of the rocker switch come with shorter wires. I have added a note to the manual to only extend them if they are shorter than 22cm. The issue on page 59 was a typo and I have corrected that as well. I apologize for the confusion on that.
Alastair Green
Thanks Chris.
