Paul McLaughlin@paulmclaughlin· 443 viewsin General Discussion
Mounting Options - Roof
Hi there,
Looking at hanging the AR2 upside down. Is it possible by default? And if not, what should I look at modifying?
Thanks again for all your help!
theres no default setup for inverting the robot. I dont see any issue why you couldnt invert it the way it is and then just be aware that Z+ is down and Z- is up. Other than that it shouldnt be an issue. I have had a couple industrial robots inverted - and there are settings to invert the robot relative to payload calculations but the base frame stays inverted as stated - the AR2 does not have have servo feedback for payload or payload settings so it should be fine.
