Kanatmetin@kanatmetin· 496 viewsin General Discussion
python3 If Input On Jump to Tab
Have you been running the go to tab command if the entry is open I am having a problem here with the verdict I was investigating in python3
ser.write (command.encode ())
ser.flushınput ()
time.sleep (.2)
value = ser.readline ()
if (value == b'T '):
ascii problem in this section
Comment1
Kanatmetin
I reached the result with an arrangement like this.
code on the arduino side
Arduino / C++
 //-----COMMAND IF INPUT THEN JUMP---------------------------------------------------
 if (function == "JF")
 int IJstart = inData.indexOf('X');
 int IJTabstart = inData.indexOf('T');
 int IJInputNum = inData.substring(IJstart + 1, IJTabstart).toInt();
 if (digitalRead(IJInputNum) == HIGH)
 Serial.println("True\n");
 if (digitalRead(IJInputNum) == LOW)
 Serial.println("False\n");
Change
python side code
if (cmdType == "If On "):
inputIndex = command.find("Input-")
tabIndex = command.find("Tab-")
inputNum = str(command[inputIndex+6:tabIndex-9])
tabNum = str(command[tabIndex+4:])
command = "JFX"+inputNum+"T"+tabNum+"\n"
ser.write(command.encode())
ser.flushInput()
time.sleep(.2)
value = ser.readline()
if (value == b'True\n'):
index = tab1.progView.get(0, "end").index("Tab Number " + tabNum)
index = index-1
tab1.progView.selection_clear(0, END)
tab1.progView.select_set(index)
replace with the problem will be fixed
I solved the problem this way. I don't know how true. but the problem has improved.
1
