hamzakhan76@hamzakhan76· 474 viewsin General Discussion
Size and Dimensions of Hardware Kit
Hi @chrisannin,
Would you know what are the dimensions and the weight of the package that the hardware kit comes in. I am just trying to figure out shipping costs and try to find the cheapest method to do so.
Thanks!
Comment4
Hello, I ship all orders via USPS priority using a medium flat rate box. shipping inside the US is typically $15, international orders outside the US is typically around $80. The Paypal store should calculate shipping for you. Let me know if you have any questions.
Erik
Hi hamzakhan76,
If it helps, the aluminum parts and hardware kit together is 7.12kg and the box size is 9.5cm x 30.5cm x 35.5cm
Kstan Simit
Just for you info, custom duty and tax me around 15% of invoice cost. I’m from malaysia.
shipping cost roughly same as Chris mentioned
hamzakhan76
Thanks for the reply Chris. Would you happen to know the weight of the package as well? I just need to know to calculate custom duties and import taxes. Thanks!
