Pierre-Alexandre Girard@pierrealexandregirard· 614 viewsin General Discussion
Solenoid valve for gripper
Hi,
I was wondering if someone could share the model of solenoid air valve you are using with your pneumatic gripper. The most common I found on Amazon are the 24V 5 ports (inlet, 2 outputs, 2 vents) 1/4: NPT
I haven't received my gripper yet so I'm not sure if one need a particular type of 2 way valve and if you guys managed to find fittings that will connect the 3mm air lines to these 1/4" ports
Thanks in advance
Any luck finding one on Amazon that works? I'm utterly clueless on pneumatic stuff... I'm not finding anything on amazon with the specific numbers 4V110-M5-DC24V. I see a lot of 4V210 DC 24V...
What are the specific specifications we should be looking for?
Patrick Sultana
Hi Pierre,
The valve I'm using is the 4V110-M5-DC24V available from many sellers on ebay. It has M5 threaded ports, made it easier for me to find respective fittings.
