Teensy 4.1 for AR3 - breakout board required?
I just rewired my freshly built AR3 robot for the Teensy 4.1 as per the upgrade manual but I'm wondering will I need to buy the terminal block breakout board module for the teensy in the AR4 manual or anything else? Thanks.
I'm looking at this one - https://core-electronics.com.au/teensy-41-without-ethernet-headers.html - and I realise I'll need a few male rather than female connectors now.
The breakout board is highly recommended. You might be able to solder the connections but I believe its worth the extra money to have the terminals. You can get the breakout board on Amazon here https://www.amazon.com/Terminal-Breakout-Module-Teensy-Version/dp/B08R7P8G9X
