ttrobotics@taylantarhan· 448 viewsin General Discussion
There is no change in values.
After making the calibration settings of the robot, there is no change in the values despite clicking on the (+) and (-) buttons of all joints.
(301) Robot - YouTube
Comment4
are you connected to the right com port for the teensy and arduino boards?
ttrobotics
Yes, I checked the connections. As I wrote, when I click on the (+) and (-) buttons, the joints move, only the values do not change.
ttrobotics
Is it your suggestion that I disassemble and reassemble all the locks?
ttrobotics
I SOLVED IT:
when using version 2.2, he read the values.the (+) and (-) minus buttons show the value.It's not just the j6 engine going counterclockwise. When you click on J6 + and minus, it moves clockwise.
