Alaeddine Brahem@alaeddinebrahem· 770 views
Wiring up the Alarm output on CL57Y Driver Stepper Motor
Hey ALL,
I'm wanting to double check I've got this right before wiring it up.
The CL57Y driver has an alarm signal output that triggers when the driver goes into a fault state. The object here is I want that signal to be picked up on one of the Arduino mega inputs so Mach can trigger an stop and halt the other drivers.
Can someone work on it can help me
Are you working on a CNC machine? I havnt used the CL57Y on the robot but I have used and tested them. I dont completely understand what you are tying to wire up to but as I recall it should just be a 5v output when it alarms.
