David Sanmiguel@davidsanmiguel· 440 viewsin General Discussion
Zero out x/y/z angle values in AR3 robotic arm
Is there a way to zero out my x/y/z angles to have the robot arm in a fixed position?
apologize if this is too obvious a question, I am new to the process.
Are you running the older ARCS software or the AR4 software? In the ARCS software for the AR3 you can click calibrate at rest position which will force the robot to the vertical rest position. I would recommend following the directions under the AR3 downloads to upgrade your robot to the AR4 software. When running the AR4 software you have the option to force the calibration to zero or home.
