AR4 wrong position move
I reconnect all cables but I have a problem with AR4 moves to the wrong position. Jog command also doesn't work correctly.
It seems that J1 and J3 axis moves with wrong angles. @chrisannin can you tell me what to check in my AR4 setup?
Can you email pics/video illustrating the angles commanded vs what is executed so I have an idea how far off each axis is. Double check that you do not have the J1 and J3 motors swapped. This has been a common mistake - with the 50:1 J3 motor and 10:1 J1 motors swapped on the wrong joints the positions will be off quite a bit. Also check your driver dip switch settings to make sure they are on the correct micro step.
@Chris (https://anninrobotics.com/community/questions/ar4-wrong-position-move) Annin You are right. I made wrong motor connections. I will change it. I will check all relevant links. I will inform you.
Did you check de J1 Limit switch? It seems like the J1 limit swtich has a false contact when GND o 3.3v has no contiue
Mateo Josue Cruz Gallegos
Espeswitch wires on the driver only one, for example the black with the green and it will change directions
