Joseph Puzzo@josephpuzzo· 528 views
J5 Tension Bearing gets stuck
Hello,
So im confused about the design of the J5 tention bearing. when you "Secure the bearing post and bearing to the J5 tension block using (1) M4x14 socket head cap screw as shown" the bearing can no longer spin. Am I doing something wrong ?
Comment7
Did you put the 3D printed spacer on?
Joseph Puzzo
I did put the spacer. When i tighten the bolt even slightly it stops the bearing from being able to rotate
Joseph Puzzo
Nevermind IT was upside down lol
Joseph Puzzo
Actually it was not. turns out my spacer was a little too thick
Could it be upside-down?
I finished my build awhile ago, can't remember exactly.
Joseph Puzzo
Nope its not upside down. Maybe the bolt just needs to be loose 🤔
Cody S
Mine was too. I had to sand down a layer or so on my print
